yes both of mine are too...my neighbor said that they should be on the inside! All the pictures I have looked at the hinge is under it sooo.
"We don’t stop playing because we grow old, we grow old because we stop playing." ![]() |
The hinge should be between the headlight panel and the front casting.
If you look at the under side of the hood extension there is a provision for the hinge to fit into.
I saw that! The hinge that is on my 108 must have been replaced by the PO at some point cause it is about 3/4" above the nose casting when in place...I will have to trim it up a bit.
![]() Quote:
looking at your picture if my eyes aren't playing tricks on me since I have been up since 4am...your hinge is mounted on the inside of the headlight panel. I looked again at mine last evening and it is between the panel and the nose casting. As Yosemite Sam said there is a notch in the casting for the hinge. The PO of this 108 replaced the hinge at some point and it wasn't drilled right so when I put it back together I wasn't sure which was the correct way...the way mine is mounted now with a different hinge you can see the top part of the hinge when looking at the front of the tractor. I will have to trim it off some.
Ironman that is one nice looking 149 ya got there!!!!
![]() Quote:
