Old 10-07-2016, 09:08 AM
Steve149's Avatar
Steve149 Steve149 is offline
Default Hood Alignment
I was working on my 108 the past couple weekends now and was fixing an issue with the hood hinge. The PO must have replaced the hinge at some point as the hood and nose casting set too far above the grill housing. After I got this adjusted I had to move the grill and hood back a bit as there was a gap between the hood and the dash cowl. Am I thinking correctly that the hood should rest on the stepped down part of the dash cowl with little gap?
Secondly, the diagram shows a rear hood mount that has 2 rubber bumpers on it. Is this support adjustable as in up and down? The PO put a piece of rubber fuel line on the hood to keep it from vibrating which didn't work very well as it has both sides of the dash messed up.
