#31
There's some good prices on eBay but I can't speak to there quality.
#32
Check out Surplus Center. http://www.surpluscenter.com/Hydraul...-9-1649-04.axd
#33
So, I finally finished my spindle upgrade that I started back when;
http://www.onlycubcadets.net/forum/s...&postcount=159 I just been having a hard time justifying the $$$$$ when I already had a set of decent tires and rims on my 1200. But I aint to good with discipline, dang!, I couldn’t even spell it without spell check. So, again,… I been squirlin away parts and stuff for sum time and now, after our most recent snow event, I have decided that… It should go on the 1650. Might make steerin better. |
#34
So some of the stuff I got, is some of these rims,…
http://www.cedarrapidstire.com/produ...-75-0815293266 hey look, these guys are listed on our site under “Resources” (hope that means they support the site) Some tires, http://www.amazon.com/dp/B005O5WV4E/...J85RK7RJ&psc=1 Valve stems; http://www.amazon.com/dp/B00LAJTEFW/...I29G2OM9O91GRH Sure is a lot easier to mount these little tires when you can bolt the rim down. I got the rim on one of these; http://www.northerntool.com/shop/too...ct_13610_13610 Which is bolted to a section of utility column that I got buried in the ground. In the machine shed. |
#35
And sum of these tie rod ends, da#n, these things are slick as snot!
http://www.mcmaster.com/#catalog/122/1243/=10vu340 Part # 4444T931 |
#36
I pulled the steering wheel off with this rig;
http://www.onlycubcadets.net/forum/s...47&postcount=1 And added a front wheel bearing for the steering column; http://www.onlycubcadets.net/forum/s...82&postcount=9 |
#37
And one of those NICE bearings:
#38
Maybe one day I will even rebuild the steering box;
http://www.onlycubcadets.net/forum/s...0404#post30404 And add a remote grease fitting; http://www.onlycubcadets.net/forum/s...351#post389351 And do the neutral adjust on the hydro linkage; http://cubfaq.com/neutraladjust.html And do the tighten up on the front axle cross member; http://www.onlycubcadets.net/forum/s...073#post338073 I think (on occation) that I’ll get to the last few things when I pull the engine out of this pig in the spring.
#39
#40
Looking great!! I grew up on a quietline.. great tractors when they are right.. Looks like you got a pretty good one.
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
