Old 01-14-2016, 12:45 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Of the 5 cyclops tractors i have used, not one had a sticky valve.
Try this... loosen the bolts that hold the valve to the dash, then give it a go. Sounds crazy, but it actually works.
Not sure why, maybe too much stress on the aluminum valve body?
1- 1200 in pieces
1- 1864 in pieces
Old 01-14-2016, 08:31 PM
Ikea6e Ikea6e is offline
I'll try that. You never know.....
Thanks, Ike
Old 01-14-2016, 08:58 PM
TIMCRUTCHER TIMCRUTCHER is offline
Not sure why, maybe too much stress on the aluminum valve body?[/QUOTE]
I experienced this when stacking the valves. Tightened them too tight.
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 01-15-2016, 08:31 AM
Rescue11's Avatar
I experienced this when stacking the valves. Tightened them too tight.[/QUOTE]
Ditto, where i got my experience
1- 1200 in pieces
1- 1864 in pieces
Old 01-15-2016, 10:27 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I had a sticky valve happen on a 782 I used to own. It was stuck in one position or the other and when my wife went to use it, said she could not adjust the deck height. I saw the problem immediately and recentered the other lever. After the mowing was done, I took another look at it, and by moving the lever through its range several times it freed up. I figured it was just due to not enough use.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
