Old 08-28-2015, 08:01 AM
jeepchicken5000's Avatar
here is a few pics, the red you should clear coat because it seems to keep its shine better, oh the reason that tractor supply doesn't sell Valspar any more is because of stupid EPA issues with the paint, I never used it but heard good things about it, I still use majic as it suits my needs
1981 cub cadet 682
1966 cub cadet 122
Old 08-28-2015, 08:56 AM
mobermiller's Avatar
mobermiller mobermiller is offline
Originally Posted by Jonah Close View Post
I just finished up painting an 1810 with Magic brand enamel from Tractor Supply and I can't say Im too impressed. It went on thin and runny so only light coats could be applied. Took a long time to dry and doesn't seem to harden up real great either.
It looks pretty good but only time will tell how durable it'll be...
I have used the Majic brand rattle cans as well as their enamel paint. I have to agree that the cure time is longer than most paints I've used, so keep that in mind if you're doing a project that needs to be done quickly. I'm getting ready to paint an O and am going to use the majic enamel.
I shot a fender on an 1810 recently and used Majic brand paint. I followed the directions to the letter. The paint was way too thick when I shot it. I should have thinned it more, but it went on really well. It had a really nice shine, but since it was so thick the cure time was REALLY slow! I left the fender in the sun to cure for several days. I am going to double up on the hardener and the thinner when I shoot the O.
The photo is of a 1650 that I painted 13 years ago. I used Cub Cadet enamel from a dealer. I sold the cub a year later. The 1650 had a rough life after I sold it. The PO caught it on fire, thus the pealing and flaking of the paint on the hood. If you look close you can see where the decals started to melt. It was left outside in the weather probably a 1/3 of the time. I was a daily driver past this persons house and would see it sitting outside. I just bought it back and am really surprised how well the paint has held up after 12 years of abuse. In my opinion the Cub dealer paint is a durable paint.
Old 08-28-2015, 11:00 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Here is a picture of the fenders and frame plus all the other little parts after 3 coats of the Magic stuff. It's definitely a learning experience!
Speaking of fenders, where can I get the rubber foot pads?
I like the metal ones Xtrememotorworks sells. He also has rubber too.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-28-2015, 07:12 PM
bkw3614 bkw3614 is offline
I am reading this thread with interest.
For all you painters out there, how big of an air compressor do you have and what would be a good one to get without breaking the bank or enriching the power company?
Also, in shooting red, some advocate a clear coat. I have a 782 problem that I am trying to remedy, and I need to paint it. I don't have the means to sandblast it, so it will be a wire brush and sand, sand, sand. I want this tractor to be nice, but I am no painter. What paints would be good to use for primer, red, and clear, if necessary?
Thank you in advance. This is another great thread.
Brian Wittman
Old 08-28-2015, 07:27 PM
TheSaturnV's Avatar
Let me clarify that my comments on Majic paint are restricted their rattle cans. Looks like you fellers are making the bulk-pack stuff work.
bkw3614:
You really don't need a big compressor to spray paint. Spraying HVLP guns requires very little pressure, so even base homeowner models can easily keep up. However, it's all the painting prep work with DA sanders, etc., that will require a much larger compressor.
Old 08-28-2015, 07:49 PM
Agree with Saturn. However even though I've done a few tractors with majic school bus yellow in the gallon, hardener, and thinner, it's still not great and scratches very easy. I go strong and mix 4:1:1 so the dry time is way fast. I store mine inside so they will vertually never fade. The gloss is still there big time but again, scratches easy and flakes off if you ever have to turn out bolts to repair anything. I've been convinced by others to spend the money and go the urethane paint route, epoxy primer, etc. we put so much effort in these things to look great with sandblasting and prep, why not use quality paint and be done. The rattle cans vs hvlp also there's just no comparison.
Old 08-29-2015, 02:03 AM
Bill410 Bill410 is offline
Originally Posted by bkw3614 View Post
For all you painters out there, how big of an air compressor do you have and what would be a good one to get without breaking the bank or enriching the power company? ... I don't have the means to sandblast it, so it will be a wire brush and sand, sand, sand. I want this tractor to be nice, but I am no painter. What paints would be good to use for primer, red, and clear, if necessary?
Brian Wittman
The HVLP guns don't take much air at all - and remember that most GT's are small spray surfaces, so even with a regular siphon gun, a reasonable compressor should keep up as long as you can pause between objects.
I use a 30 gallon tank/5 hp compressor in my shop, but have sprayed off a 10 gallon 2 hp one before for small stuff. Starting at around $130 at Harbor Freight or Princess, on up to around a grand for a nice home use compressor. I used an old sears one that was given to me and I replaced the reed valves in for many years!
As far as paint, my best recommendation is to go to your local auto paint store and talk to them about what you want to do. Some things go together and others don't, so they can keep you compatible. Basically, your looking at a primer (go with an epoxy primer/filler to fill in your scratches and imperfections - you can get thick stuff that is almost a spray bondo filler..), maybe a sealer, depending on what you are covering, and a base/clear combination or just a color coat of paint. There will also be reducers, catalysts, hardeners, etc depending on what brand/type you use.
You will also need some supplies - lacquer thinner/acetone (depending on what you use), degreaser, tack cloth, masking tape, etc Again, the paint store can steer you in the right direction...
If you don't have much paint experience, you can practice on a cardboard box - the edges and horizontal/vertical surfaces mimic what you do on the tractor and you can get used to the guns pattern.
Oh, and with red, you hit the jackpot! Because of pigments, red is one of the most expensive colors to buy. But it generally covers well (unlike yellow).
Old 08-27-2016, 10:14 PM
tbone tbone is offline
Default Rust-Oleum Professional Enamel
I know this is an old thread but the subject of which type/brand paint to use for my Cub 125 is making me crazy. I am a novice when it comes to painting with a spray gun so I am looking for a paint that will be durable, close to the 483 Yellow and 902 White on my Cub 125, and simple to mix and apply. I have sand blasted all my parts and applied Rust-Oleum rattle-can primer. From what I have read, I should use the same brand primer and enamel paint. Having given you that background info, is Rust-Oleum Professional High Performance Enamel Paint an acceptable paint and are the Rust-Oleum Safety Yellow and Gloss White colors reasonably good matches to the Cub 483 Yellow and 902 White? Any and all thoughts will be appreciated.
Old 08-27-2016, 10:40 PM
ccguy's Avatar
ccguy ccguy is offline
tbone:
All the previous comments still apply.
I have never used Rust-Oleum Professional High Performance Enamel Paint but have used their regular primer...and don't care for it as it takes forever to completely dry. Having used Majic and Valspar rattle cans and quart cans, I can say hands down, Valspar (using their reducer and hardener) is easier to professionally apply, gives a better high gloss and is more durable.
If matching to the original OEM color is important to you, stick with a paint that is matched to those colors and labeled as such, i.e. IH White, IH Red, Cub Cadet Yellow, etc.
If you do move forward with the R-O, give us a report and show us how it came out.
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 08-27-2016, 11:30 PM
ccguy, thanks for your response. Since I have used the Rust-Oleum primer do I really have to use Rust-Oleum paint. Is it acceptable to use another brand of enamel, even an automotive acrylic enamel, over the Rust-Oleum primer?
