-Ryan
Ryan, I have been meaning to do the same right-up but I will let you do it as I can't type near as fast as most, but our commands have the same problem and will get the relay to fix those nasty click-no-starts fixed!!
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
golfnuts
Of the few 2000-3000 series tractors I've been around, they all seem to require a heavy foot on the brake pedal to engage the start safety switch. Drove me nuts trying to start my 3206 the first time. Depress the brake pedal all the way, then push it a little more. MTD put the switch all the way to the bottom of the pedal travel, and if your brakes are well adjusted or seldom used, it takes some effort. Mike |
I have been dealing with an intermittent start with my 1864, 18 hp Kohler Command. By moving the wiring harness plug on the starter switch while turning the key to the start position, the starter would spin the engine to start normally.
Yesterday, with some warmer weather in Pennsylvania, I finally removed the starter switch and plug for cleaning. Nothing looked burned or signs of arcing. I did give the female spade terminals a bit more compression and assured the individual connectors were fully seated on the starter switch. Fingers crossed no more dead start attempts. |
Cub Cadet's I have are (1) IH 782 for pulling Trailer, (1) CCC 1711 GT with 44" Mower (1) CCC 2284 SGT with 60" Mower and (1) CCC 1864 SGT with 50" Mower. Farm tractors I have are 1956 Ford 641 and 2005 John Deere 5320 with Loader. |
Sorry 'bout that golfnut.
I re-read your first post and realized you have a Cyclops SGT. Around here, 2284's are rare enough the model number didn't register with me. I was thinking the later MTD 2000 series. ![]() The Cyclops tractors aren't really all that different from your 82 series stuff. I think everyone is correct on looking at the ignition switch and plug. Mike |
I looked around in my picture files and found a pic of a CH22 that was in a 2284 that had the relay on it. Not the best pic. Anyway it seems as though the CH's and the Kubota's have more problems than some of the others. My guess and it's only a guess is that the starter solenoids on them require more juice than is able to be supplied through the maze of switch's, plug connectors and the crappy wiring harness on the Cyclops.
![]() I have been experiencing what sounds like the starter solenoid bringing the armature gear into the flywheel but no turn. I have changed the battery, ignition key and starter but no change. I even took out the plugs to see if it will spin. or not. Still no change. Noteworthy is I pulled the start.r away from the flywheel and grounded it. the starter spins EVERY Time. |
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
