Cub Cadet 2284 won't start!
Hello Cub Cadet fans. I have a Cub Cadet 2284 Super Garden Tractor that I'm having trouble starting. Last time I used it to mow it did fine and after sitting in the shed it now will not start. When turning the switch to start the low oil light comes on and I hear a clicking noise on top side of engine but the starter does not engage. Is the clicking noise I'm hearing coming from the solenoid? I don't know where the solenoid is located on this tractor. This tractor is new for me as I am familiar with the 82 series tractors. So before I starting tearing into the problem it would be nice to have an idea where to start looking. Any help would be very much appreciated. Thanks. Larry.:beerchug:
First, I would make sure that the Battery is fully charged. If that don't fix the issue, then on to step 2. Take off and clean the Positive and Negative Battery cables, from both ends, and make sure the ends (and their connections) are: clean & bright. Then re-install the cables and make sure the connections are tight.
Report back. |
+ 1 on the good info,plus make sure you check the oil before you start it.
The oil light should come on, clicking at the top of the engine is the fuel shut off solenoid doing what it should when it is energized. My guess is that you are not getting power to the starter solenoid. |
Thanks Sam Mac. Do you know where the solenoid is located? I would like to do voltage check to see if voltage is ok. If not 12 volts I think R Bedell may have the solution.
I have a 2284 that has a starting problem also if I hit the key 10-15 times it will finally start FrankF3 sent me the updated wiring schematic on how to fix this issue I have not had a chance to do it yet. If you pm me your email I can forward it to you.
Ryan, I have been meaning to do the same right-up but I will let you do it as I can't type near as fast as most, but our commands have the same problem and will get the relay to fix those nasty click-no-starts fixed!!
golfnuts
Of the few 2000-3000 series tractors I've been around, they all seem to require a heavy foot on the brake pedal to engage the start safety switch. Drove me nuts trying to start my 3206 the first time. Depress the brake pedal all the way, then push it a little more. MTD put the switch all the way to the bottom of the pedal travel, and if your brakes are well adjusted or seldom used, it takes some effort. Mike |
| All times are GMT -4. The time now is 06:52 PM. |
