Old 04-01-2015, 03:22 PM
Terry C's Avatar
Terry C Terry C is offline
Default Narrow Frame Gas Line
Hi all,
Should all NF have a brass fuel line with a bowl? Only my 105 does and I guarentee the other ones that have a rubber hose are not factory.
So if the gas tank was attached to the engine it should have brass line?
Thanks
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-01-2015, 03:58 PM
Pretty sure "factory" is steel, not brass.
Nothing wrong with using rubber.
Old 04-01-2015, 04:10 PM
Terry C's Avatar
Thanks for the quick answer. I'm restoring these so just trying to get what should be on there
Terry
3225
Old 04-01-2015, 04:12 PM
If it's a restoration, I completely understand wanting "OEM". Check with Lew, but like I said, pretty sure OEM was steel.
Old 04-01-2015, 04:38 PM
ccarney ccarney is offline
only the original had copper fuel line if I recall correctly. the 70 on up all had steel fuel lines until the wide frames.
Old 04-01-2015, 04:59 PM
Terry C's Avatar
Thanks all for the answers.
Terry
3225
Old 04-01-2015, 05:10 PM
Merk Merk is offline
My 100 and 70 has a steel line and brass fittings.
Project Uncle Dick
Cub Cadet 70
Old 04-01-2015, 06:47 PM
I started making some sets for the 10-14 hp ones,I need more rubber bushing material for the 7 hp ones
Old 04-01-2015, 07:03 PM
Terry C's Avatar
You going to make up enough to share?
Terry
3225
Old 04-01-2015, 07:49 PM
He has shared in the past but I think he shared too much. I can say that now
