Old 05-27-2010, 08:06 AM
T-Mo's Avatar
T-Mo T-Mo is offline
I don't think the gauge type cap was original to the 127, but was probably added by a previous owner.
Old 05-27-2010, 08:07 AM
labrati labrati is offline
Originally Posted by gcbailey View Post
The fuel cap is one that has a guage on it (f-e). I didn't know if that was factory or not.
I don't think it has the breather hole like my original does.
My 127 (1970) has a metal cap with two plastic insert plates that make a breather of sorts.. has a needle sized hole in the top of the cap...
My trials and tribulations have been related to low fuel when parked on an angle.. my tank has sort of a false side in it... on the fuel line side of the tank you'll notice a small protrusion on the bottom.. this, I gather, is where the fuel flows into the side where you can't see.. If you look at the tank you'll note it's shorter on the inside than the outside.. I'd make sure you have plenty of fuel and that fuel is making into the false wall side.. perhaps you've got gunk that got into that other side? and also.. I've torn the whole fuel system apart only to find that the fuel valve on the sediment bowl was closed...
Old 05-27-2010, 08:10 AM
T-Mo's Avatar
I had my 123 die on me once - like it ran out of gas. Check the gas tank, it was almost full. Then I noticed that the shut off valve on the sediment bowl vibrated shut - I didn't tightened it all the way counter-clock wise when I opened it.
Old 05-27-2010, 08:39 AM
TEET's Avatar
TEET TEET is offline
Same thing happened with my 127.....which has a metal cap with a cork gasket, or should I say HAD a cork gasket. It fell in the tank and crumbled into fine pieces, eventually making it through the screen in the sediment bowl and into the carb.
Cleaned all that junk out, and no more problems.... Sounds like your issue is something similar
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 05-27-2010, 09:13 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I'll try dissecting the gas tank and carb in a few days. I guess I'm heading to the Smokey Mountains. Nice to know the night before!
Gary
