Old 09-13-2014, 06:56 AM
randallc randallc is offline
Default Barn find
Went to look at a disabled cub, a 125 sitting next to it. Only 3 mile from home so brought them both back. Owner said he got tired of the 125 throwing the belt each time he raised the deck and parked it several years back.
Got the sticky old gas out and the carb cleaned, will change the oil and see if it will fire.
It appears to have a mule drive for a tiller since it has two adjustment bolts and not a spring on the one side. And it is terribly out of adjustment and maybe the wrong belt. Will check that out.
Do I need to get a mower mule drive or will the tiller one work if adjusted?
Have not got to do much work to it yet. Don't know the condition of the engine, time will tell.
Old 09-13-2014, 10:17 AM
kostendorf's Avatar
Just find this part, and the spring. IH Mule Drive Idler ratchet PN/ IH-59690 C2 USE IH-59690-C3
Fits 44 44A 50 50A Mule drives
Old 09-13-2014, 11:21 AM
I'd get the spring and put it back the way its supposed to be. The reason for the spring is to auto adjust the belt tension to allow you to move the deck up and down, the 2 bolt setup won't self adjust and is probably 99% of the reason it throws the belt.
Old 09-13-2014, 12:04 PM
IHinIN IHinIN is offline
My 100 has the same mile drive setup without the spring on it and it never throws the belt. Just be sure to use the 3/8" CC belt. A lot of people use an "A" width belt which is too wide to fit down into the pulleys deep enough.
Old 09-13-2014, 02:56 PM
Same here. No issues yet. Glad you got them both. Good haul. let's not fix the issue of the belt throwing, just park it. it worked out for you though.
Old 09-13-2014, 09:46 PM
OK, on all response. Will get it running and try it with proper belt. Thanks for all the responses.
Old 09-14-2014, 07:41 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Attachment 56394
I do not think that will fit on a 125 mule drive which uses a spring on one side and a threaded rod on the other.
Old 09-15-2014, 06:17 AM
It runs good, but a bit of a loose spark plug. Should I put a spark plug repair kit in it before using it?
Now on to the mower belt/drive issue.
Old 10-02-2014, 10:49 PM
New idler pulley, straightened the pulley holder shaft, proper belt, greased and worked like a charm.
Old 10-02-2014, 11:20 PM
bolivier's Avatar
bolivier bolivier is offline
What did you do about the spark plug?
