Old 12-02-2013, 09:32 PM
garnold's Avatar
garnold garnold is offline
Those grooves are not supposed to be there. The pin hammers against the sides of the slots and causes the grooves. They can be welded up to repair the hub but will return over time. Some guys choose to replace the driveshaft with the Quietline style shaft with the flex joints on both ends.
Could I see a picture of this? Interesting how you can pull parts from other cubs into the mix. I'd like to see this.
