Old 12-01-2013, 09:30 PM
bombur bombur is offline
Default 129 hub assembly
The shear pin broke and when I took the hub assembly off there were two semi-circular cut-outs where the dowel presses against the grooves in the hub. Are those cut outs supposed to be there or were they worn into the grooves by the old pin?
Old 12-01-2013, 09:34 PM
A picture would certainly be helpful. All of my 129's (I've had around 5 of them) have had a little channel cut out of the hub. However, if the channel is worn away, then it is time for a replacement--that is why a picture is necessary to assess your situation.
Old 12-02-2013, 09:14 PM
IHinIN IHinIN is offline
Those grooves are not supposed to be there. The pin hammers against the sides of the slots and causes the grooves. They can be welded up to repair the hub but will return over time. Some guys choose to replace the driveshaft with the Quietline style shaft with the flex joints on both ends.
Old 12-02-2013, 09:28 PM
Makes sense, thanks
Old 12-02-2013, 09:32 PM
garnold's Avatar
garnold garnold is offline
Could I see a picture of this? Interesting how you can pull parts from other cubs into the mix. I'd like to see this.
