Old 09-13-2013, 08:41 AM
OldAndInTheWay's Avatar
Default Trouble with drive shaft... Kohler has too much torque..
Old 09-13-2013, 08:48 AM
jimbob200521's Avatar
Doh, I hate it when that happens!!
-Ryan
Old 09-13-2013, 08:51 AM
That looks EXPENSIVE! What is that in?
Old 09-13-2013, 09:01 AM
mickb72 mickb72 is offline
Default cub
HAhahahahahaha, fine spline to boot! Mike
Old 09-13-2013, 09:29 AM
That is not a torque failure, that is a fatigue failure.
The failure was most likely caused by some form of defect on or near the surface of the shaft.
This type failure is indicated by the "beach marks" shown at the top of the shaft.
Mis-alignment may have also been the culprit!!
If that is the case, a Kohler twin could have caused the failure!!
Old 09-13-2013, 01:27 PM
Now that's some damage!
Was on a mining machine. Cost $24,000 for every hour of down time.
Cost $630,000 parts and labor.
Old 09-13-2013, 01:36 PM
oops!
Old 09-13-2013, 10:55 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
That's why you shouldn't remove the rag joint on your 1811. When the ISO mount's fail it will shear the shaft off. The twin 18 is a animal!
Old 09-14-2013, 07:35 AM
How about a pic of the machine?
