Are these the same frame? The guy I bought the 123 from is giving me a rolling 122 chassis with it. I am wondering if I can swap the frames because the 123 has a cutout above the hydro in the frame from the PO before him.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
They are exactly the same tractor only the 123 has a hydro tranny while a 122 has a 3 speed gear tranny.
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Thats what I thought, Thank you!
Keep in mind you will have a creeper breather hole and shifter hole in your tunnel cover if you switch frames. Not a big deal, just a minor difference in frames. It wont affect how it functions.
Good point, That was the response I was looking and waiting for. Wasn't sure if the 123 had a creeper/breather hole originally or not (Since mine is cut out to begin with). Thank you sir!
Your 122 frame will not work without some mods to it.
First off the hydro linkage that goes through the frame is different, it would have to be larger and the you would have to drill holes in the correct spot for the hydro control. Also the hydro has a hole in the side of the frame for the release lever, you wouldn't be able to mount it any way without the mounting holes for it inside the frame. Just my 2¢
Is the large hole in the left side of the 122 frame where the hydro adjustment marks are on a 123?
Any 122 frame made before the 123 does not have it.
