Old 11-25-2011, 08:47 PM
I do not have enough snow blades to live in MI!!!
Anyway, my "toys" are temperature sensitive!!
So are their owner!
Old 11-25-2011, 09:10 PM
So are their owner!
Like most other things at my age, I know how much snow I can (can't) handle.
AND 44.7kW of snow is my limit!
Old 11-28-2011, 09:22 PM
Well, I got the 55 pounds of weights installed in their hidden location.
My WAG of the hole locations worked out just fine, I didn't have to match drill through anything important.
With the addition of my hidden weights, sleeve hitch, spring assist and modified
hitch I guess I have added 100 pounds to the back of the QL 1000.
Now the mice and mud will have a harder time getting in the battery box!!
I also changed the 6 bolts that holds the transmission to the frame to grade 8 just in case that connection does not like all that additional weight!!
If it ever snows, I have a set of loaded 10.50's with chains standing by, so with a quick tire swap, the QL 1000 should be ready to go.
Until then, the QL will do light yard work duty, waiting for spring, complete dis-assembly, and a new paint job.
Old 11-28-2011, 09:37 PM
LarryW's Avatar
LarryW LarryW is offline
Nice work as always!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 11-28-2011, 10:24 PM
Ditto!
Old 11-28-2011, 10:31 PM
cub1450's Avatar
cub1450 cub1450 is offline
Looks good CADplans.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 11-29-2011, 12:50 AM
72-149's Avatar
72-149 72-149 is offline
Attachment 17914
Attachment 17915
Attachment 17916
Attachment 17917
now they need to be powder coated cub yellow so they dont rust or bleed on the tractor
Old 11-29-2011, 11:44 AM
You did good! Lots of extra weight in a little space. The mice are going to be mad!
