What is the length of a super tunnel cover from the dash to the front of the fender pan.
Thanks.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
Looks like about 16 13/16" on the top but it angles on the bottom. Are you making a new one?
To many ideas, not enough time..... Cub Cadet 147 2050041u340160 Cub cadet 129 main mower Cub Cadet 1811 Cub Cadet 1872 with 60" CCC deck. Many Mower Decks, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" and 12" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade. |
I have mine off now so if you are making one I could get more measurements if needed.
No I`m not making one just trying to figure out where to mount the fender pan on my 1650SGT aka Super Quietline
http://www.onlycubcadets.net/forum/s...ad.php?t=12478
Get you a tunnel cover first then mount the fender pan. I know, patience isn't always a virtue. LOL
I measure the distance from the dash to the pan and its 16 9/16 on the flat part of the pan. It has the little curved part on the top of the tunnel cover that I didnt measure from.
Thanks Larry
DWayne I ain`t bolting it up right now just getting the metal peices welded on to raise the fender pan,and yes I am waiting to get one.
Larry could you also measure the height of the peice of c channel on the frame used to raise the fender pan
Thanks
Does this help?
Wow! nice job on the measurements. This pic should go in the tech section!
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
