| View Poll Results: shoul i paint it red or yellow and | |||
| red |
53 | 39.26% |
| yellow and white |
82 | 60.74% |
| Voters: 135. You may not vote on this poll | |||
I have a parts 1000 that i sold the motor and transmission out of and i got to thinking if i stretch the frame and do the rest of the modifications i could have a one of a kind super i got it mocked up right now i`ll get some pictures later.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
Looking forward to your pics!
If you can take pictures of each step that you do.
Here is the mock up
I plan on adding a piece on the back because I`m afraid if I cut the chassis in half it will weaken it to much. 2011-08-03 10.23.48.jpg Of course it will have super tires and wheels 2011-08-03 10.24.03.jpg The back fender pan bolts will bolt in the front 2011-08-03 10.24.11.jpg 2011-08-03 10.24.33.jpg
Sounds like a great project! Looking forward to your progress!
Actually, the back is where the extra length is on a super anyway...my 1872's frame has the rearend bolt holes and 3-point hitch upper holes, and then a few inches further back it has the holes the tractor uses to attach the rear.
Great idea, I was also thinking about stretching a quietline, I recently picked up a 1650, and have a line on a 1450 roller to go along with my 1250. Once I finish restoring the tiller that came with the 1250, my plan is to get after one of the tractors. Being 6 foot and a less than solid 280 lbs maybe a stretch is in order!
Bob. 2550 with sleeve hitch 1250 with tiller, blade, deck 826 snowblower Past machines 72,1650 |
Didn`t get much done today exept cut the crossmember out for the fender pan and got the implement handle off. I liked to have never got the roll pin out of it luckily I have a hot wrench(a torch)
![]() 2011-08-04 18.33.30.jpg2011-08-04 18.33.43.jpg I also put the bigger tires on
This looks to be an interesting project, looking forward to seeing it finished.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I am liking the idea of the extended wheel base, will keep my eye on this one!
I have been thinking about your project, seems pretty straight forward in concept. Was wondering what your plan is for the clutch/ brake pedal? Do you plan to move it rearward in the frame, the same amount as you slid the fender pan/ rear end and trans, placing back in the same perspective with the foot rests that it had originally? I guess another option would be to cut the pedal off it's mount and adding a piece to it that runs in line with the bottom of the frame, to move the pedal assembly rearward back in position over the foot rest. This would be the easy solution, but the added length would make an odd travel if the pedal when pushing it with your foot, as it traveled forward, it would also travel upward....hhmmm...probably a bad idea. Just thinking aloud...
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
