Old 04-20-2014, 07:32 PM
Default My 149 and it's problems.
Put the 149 up on the lift today to do a good check out. If I was smart I’d part it out but I’m not all that smart. Here is what I have found so far. PTO is toast, broken and missing bolts that hold the rear end in place (and you guys thought it was only the aluminum rears the had this problem) choke and throttle cables are frozen and need to be replaced, drive shaft is a mess, gotta love the grade 5 bolt (I have a plan for this) axle seals are leaking (BTDT) Oh yeah 2 of the 4 bolts that hold the engine in are missing. Not sure about it charging, wiring looks like poop, brake pads are shot, the seat is trash. Hydro lever is loose and I can’t get it off the shaft. Let’s not even talk about cosmetics. I’m out of my mind but I’m gonna patch this turd up enough that it will run the tiller.
Old 04-20-2014, 07:38 PM
Sam, I'm sorry the 149 needs so much work, but I'm sure with your skills , it will be fixed up in no time , btw, I just had to do some work on my 149 today, only needed a new fuel line, spark plug, and coil wire.
Old 04-20-2014, 07:40 PM
Sam,
Sounds like the 127 I had,I am sure the frame has a crack in it somewhere.
You know who has the parts...
Up to 530 and counting...
Old 04-20-2014, 07:48 PM
Sam,
Yes lew, he knows who has the parts.... You!
Old 04-20-2014, 08:01 PM
Sam,
Have not found a cracked frame, yet. Gonna pull the fender pan and pressure wash the pig to see what I have. I know the rear and the engine are coming out. This is going to be a very low budget fix or it's getting parted out. Engine runs great and the trans seems to be good. If they had issues it would be parts city for it. Oh yeah I forgot the head lights work perfect, LMAO
Old 04-20-2014, 08:05 PM
But Sam...........it's a 149
Old 04-20-2014, 08:09 PM
Oh Goody Goody. I'll take a Ratty Cyclops over this POS any day. Only reason I may fix it is for tiller duty. 1maybe 2 hours of use per year. I need a lobotomy.
Old 04-20-2014, 10:50 PM
OffTime's Avatar
OffTime OffTime is offline
X2 It is a 149. Doesn't sound too far removed from my 129. Wiring, trans leaks, control lever splines stripped out, etc, etc. Why don't you just load it up and make the skip and hop down here to GA and we'll fix up our Cubs together. I got the trans out of mine right now.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 04-22-2014, 03:12 PM
Default Need PTO parts and help
Guys
I'm new to this style of PTO so I need a little help. I need the following items
Cub Cadet IH-473477-R3 Button, Thrust (14 in the green circle)
Cub Cadet IH-473478-R2 Lever, Throw-Out qty3 ( number 25 in the green circle)
These are available but the clutch disk seems to only be sold with a complete clutch. (number 20 in the red circle)
I understand that I also need a setup gage, anyone have one I can borrow?
Are any of you guys doing/selling rebuilt clutch's ?
I'll get the button for the lever from Jeff
Old 04-22-2014, 03:30 PM
jimbob200521's Avatar
Did you check with one of the sponsers at the top?
http://ihcubcadetparts.net46.net/1_2_Products.html
He sells one listed as:
REBUILT Wide Frame Style, Manual Front PTO.
This isn't some taken apart "cleaned up" and put back together PTO this one was rebuilt with a New Cub Cadet fiber disk, new springs, new center button and adjusted as per adjustment gauge. Comes with 6 new set screws, adjustment gauge, and instruction sheet.
$130.00 *EXCHANGE, plus $13.75 shipping including insurance to anywhere in the lower 48.
Core Charge $50.00
-Ryan
