Old 04-21-2014, 10:32 PM
IH Cub Cadet IH Cub Cadet is offline
"little pig"
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 04-21-2014, 11:41 PM
The 149 is looking good, Sam.
Old 04-22-2014, 01:55 AM
The turning of the wrenches will begin tomorrow. It may live on in scenic Galax.
Go get'em bud!
Old 04-22-2014, 03:41 PM
Got the PTO apart today and the fender pan off, even the screws that hold the foot pads came out with no problems. The little pig is growing on me. I'm going to have to make a special set of rear end braces for it, the brake levers are in the way. No big deal. It has on broken bolt in the rear where it attaches to the frame and it's missing on of the brackets that bolt to the frame near the pump so the whole rear was rocking up and down. I've seen worse. Steering wheel is off. What's the secret to getting the forward reverse lever off, I have the set screw out? Think the PO got all the goodness out of the PTO fingers, button is gone and they ran it right into the lever.
Old 04-22-2014, 04:12 PM
Default Need PTO parts and help
Guys
I'm new to this style of PTO so I need a little help. I need the following items
Cub Cadet IH-473477-R3 Button, Thrust (14 in the green circle)
Cub Cadet IH-473478-R2 Lever, Throw-Out qty3 ( number 25 in the green circle)
These are available but the clutch disk seems to only be sold with a complete clutch. (number 20 in the red circle)
I understand that I also need a setup gage, anyone have one I can borrow?
Are any of you guys doing/selling rebuilt clutch's ?
I'll get the button for the lever from Jeff
Old 04-22-2014, 04:30 PM
jimbob200521's Avatar
Did you check with one of the sponsers at the top?
http://ihcubcadetparts.net46.net/1_2_Products.html
He sells one listed as:
REBUILT Wide Frame Style, Manual Front PTO.
This isn't some taken apart "cleaned up" and put back together PTO this one was rebuilt with a New Cub Cadet fiber disk, new springs, new center button and adjusted as per adjustment gauge. Comes with 6 new set screws, adjustment gauge, and instruction sheet.
$130.00 *EXCHANGE, plus $13.75 shipping including insurance to anywhere in the lower 48.
Core Charge $50.00
-Ryan
Old 04-22-2014, 04:41 PM
Sam you can get clutch disk seperate and rebuild kits sometimes come with clutch fingers. Is this for your 149? You need a wide frame gauge as they are different from NF one
Old 04-22-2014, 05:15 PM
sawdustdad's Avatar
I've been buying clutch rebuild kits--approx. $60, comes with the fiber disk, triangle springs, and the setting gauge. all the parts you might need are here:
http://ihccw.com/pto.html
I have a setting gauge I can send you gratis...I've got several, just let me know. PM me with mailing address.
Old 04-22-2014, 06:08 PM
you can buy just the clutch discs on ebay at a reasonable price, i have a gauge if you want (nf, not sure if the same as wf)
Old 04-22-2014, 06:24 PM
PM sent to you.
