i was cutting some grass today and my tractor was doing great. i was in some rough stuff so i was in first gear. all of a sudden, it stopped. i thought i was hung up on a root, so i put it in reverse and it went back no problem. put it back in first, it went a little piece forward then started a sickening grinding sound. thats my first guess. i shut her off and then proceeded to go through the gears, no problems there, so i'm thinking rearend is toast. how readily available are parts? and how much of a PITA is gonna be to repair? that god for spairs!!!!!!! jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716 Jeff |
probably just better off getting a different rear end from a guy that parts tractors
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
Watch out when Lewis's rear end lets go!!! It's not pleasant.
Yes, replacing the rear would be easier. |
Check the spirol pins maybe one of them broke. Might be shifter forks too. There's a guide in the tech section of the site.
Pull the fenders and shifter...it may be immediately obvious. There's always rearend gears on ebay, but a whole 'nother rear will be faster.
Mike,
Your not a very fart smeller are you? ![]() It would be a lot easier to find a complete rear,plug and play is the way...
Thanks guys! I will access the damage when the temp drops some. Until then, I will just put the deck on the spare cub. Thanks jeff
Pm sent....
104 to 127 conversion with dual 6x12s, hydraulics snow/dirt plow 1200 Quietline 44" mower QA-36 snow thrower |
Just another option - was in the junkyard the other day and found two old gear drive cubs, complete rear ends there for sure, maybe a few other things too, but definitely trans and rear ends, complete assemblies.
I'm in Ohio, btw. |
unfortunately, around here cubs are far and few in between. i have bought or been given all that i have found. i'm gonna wait till the temp drops and then tear into it and see the damage. i'm not in a big hurry for it, i'm gonna drop the deck and put it back on the 1200, then i will have my wifes' 1450 and the 1200. if i had to cut with anything else, i would be sick. you just can't beat a cub cut!!!! jeff
