Old 07-09-2011, 04:30 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default my rear end let go!!
i was cutting some grass today and my tractor was doing great. i was in some rough stuff so i was in first gear. all of a sudden, it stopped. i thought i was hung up on a root, so i put it in reverse and it went back no problem. put it back in first, it went a little piece forward then started a sickening grinding sound. thats my first guess. i shut her off and then proceeded to go through the gears, no problems there, so i'm thinking rearend is toast. how readily available are parts? and how much of a PITA is gonna be to repair? that god for spairs!!!!!!! jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 07-09-2011, 05:18 PM
ihnick's Avatar
ihnick ihnick is offline
probably just better off getting a different rear end from a guy that parts tractors
Nick.
Old 07-09-2011, 07:43 PM
mmzullo mmzullo is offline
Watch out when Lewis's rear end lets go!!! It's not pleasant.
Yes, replacing the rear would be easier.
Old 07-09-2011, 08:45 PM
Check the spirol pins maybe one of them broke. Might be shifter forks too. There's a guide in the tech section of the site.
Old 07-09-2011, 08:58 PM
Pull the fenders and shifter...it may be immediately obvious. There's always rearend gears on ebay, but a whole 'nother rear will be faster.
Old 07-09-2011, 10:23 PM
Mike,
Your not a very fart smeller are you?
It would be a lot easier to find a complete rear,plug and play is the way...
Up to 530 and counting...
Old 07-10-2011, 11:35 AM
jeffscub's Avatar
Thanks guys! I will access the damage when the temp drops some. Until then, I will just put the deck on the spare cub. Thanks jeff
Jeff
Old 07-10-2011, 03:36 PM
william1041200's Avatar
Default about complete 3speeds...
Pm sent....
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 07-10-2011, 03:45 PM
jsoluna's Avatar
jsoluna jsoluna is offline
Just another option - was in the junkyard the other day and found two old gear drive cubs, complete rear ends there for sure, maybe a few other things too, but definitely trans and rear ends, complete assemblies.
I'm in Ohio, btw.
Old 07-10-2011, 07:37 PM
jeffscub's Avatar
I'm in Ohio, btw.
unfortunately, around here cubs are far and few in between. i have bought or been given all that i have found. i'm gonna wait till the temp drops and then tear into it and see the damage. i'm not in a big hurry for it, i'm gonna drop the deck and put it back on the 1200, then i will have my wifes' 1450 and the 1200. if i had to cut with anything else, i would be sick. you just can't beat a cub cut!!!! jeff
Jeff
