Old 06-25-2009, 08:48 PM
bombur bombur is offline
Default 129 flexible coupling replacement
I hoped this would be an easy out/easy in project, but no. I removed the 4 bolts from the coupling arm, took the old torn coupling out but could not get the new flex coupling in. So Ithought I would remove the pin from the arm to move it a bit astern to make room for the new flex. When I tapped the pin lightly it dodn't budge, when I used more force it started to peen over. What's the correct procedure here??
Old 06-25-2009, 09:10 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Soak your pin with a good penetrating oil. Then soak it some more. Use a pin punch and hit it a little more that lightly. You don't want to hit it like you are going to drive it out. Hit it so that you set up a vibration so to speak. Get a kind of rhythm, like a blacksmith working a horse shoe. Don't beat it. let the weight of the hammer do the work. That should work.
Old 06-25-2009, 09:21 PM
clint clint is offline
Agree on penetrating oil, PB Blaster will do, also a small propane torch to heat the pin will do wonders if soaking in PB Blaster don't break it loose.
Old 06-26-2009, 06:15 AM
It also helps to have one of these....
Old 06-26-2009, 09:06 AM
RPalmer's Avatar
Hey.. that's nice! I like the tit on the end to help keep it in place. I see by the other end it has seen some use. Is that a special order tool? Or should I go on a mission to hunt one up?
Old 06-26-2009, 09:19 AM
MBounds's Avatar
MBounds MBounds is offline
RE: Spirol Pins and Pin Punches: The "tit" on the end is not to keep it lined up...it's purpose to cause the spirol pin to contract away from the walls of the hole and thus easier to remove.
Roll a piece of paper and pull the inside out of one end...and watch how the outside gets smaller...That's basically what's hapening to the splirol pins when the punch with the "tit" is used...
Myron B
Old 06-26-2009, 09:31 AM
Merk Merk is offline
Sears sells a set of roll pinpunches for $20.
http://www.sears.com/shc/s/p_10153_1...s+%26+Pry+Bars
Old 06-26-2009, 10:29 AM
murphycc
Guest
Posts: n/a
Yes I have that set, makes all the difference in the world. Do the job right. As Myron states the force is exerted to the center of the pin thus relieving pressure from the external portion of the pin.
Once mushroomed you can use an angle grinder and cutting wheel to cut off the mushoomed portion and try again. if the other end is clean tap from the other direction but with my luck the other end will be damaged too.
Scott
Old 06-27-2009, 01:19 PM
Default What's next??????
Taking everyone's suggestions, for which I am thankful, I bought some pb Blaster, put it on, used my shiny new Sears spirol pin extractor and after a few minutes the pin was out. Unfortunately even when I move the now free coupling back, there still is insufficient room to get the new flex coupling over the end of the drive shaft. Do I have to take the pin out from the engine end too? Do I have to remove the shaft?
I don't see an icon for teeth gnashing or vulgar language
Bombur
Old 06-27-2009, 01:40 PM
RPalmer's Avatar
bombur,
Make sure that the pin at the engine end of the drive shaft is in it's proper place and not in a worn out area that prevents it from moving.
