Old 03-30-2011, 02:52 PM
westofb's Avatar
westofb westofb is offline
Default U joint upgrade?
I am sure I found a link to this off this web site, but I am not having any luck finding it at the moment. The link I am looking for was to were someone upgraded the rear drive shaft by removing the original rag joint and couplers and installing a couple of yokes and a greaseable u joint in its place. Thought I might look into this once I tear into the 149 that is going to get completely rebuilt.
Is there any type of upgrade a person could do at the front of the drive shaft where it couples to the motor? Thanks for any info you can shoot my way!
Jeff
Old 03-30-2011, 03:45 PM
rmunro's Avatar
rmunro rmunro is offline
I thought about doing that. Figured two u-joints, one at engine and one at pump end.
Then decided against it. I'm not in love with the sytem, but it lasted 37 yeras. I won't be worried about repairing it again 37 years from now.
Edit to add, sorry I can't help you with the link.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 03-30-2011, 04:39 PM
TEET's Avatar
TEET TEET is offline
Is this what you are looking for?
http://cubfaq.com/davek.html
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 03-30-2011, 05:17 PM
If it were mine, I'd use all of the rag joint stuff from a QL or 82 series, with two rubber discs on each end. That will eliminate the 1x9 front coupler that can be potentially troublesome. If you use two rubber discs on each end and all new parts in the driveline, it will last a very long time. JD used U-joints on some of their shaft-drive tractors, and from what I've heard, they don't last very long. The rubber discs do a good job of absorbing the torque fluctuations from the single cylinder engine so they don't get transmitted to the rest of the drivetrain. I've had a few 82 series tractors with 1000+ hours and original flex discs in them yet.
Old 03-30-2011, 06:07 PM
aagitch's Avatar
aagitch aagitch is offline
I was considering ujoint mod for the diesel but decided against it after reading several post. To me it wouldn't be any benefit considering the time and money it would cost. I just put a new coupling and flex discs on the drivetrain of the diesel and it is awesome smooth now.
Adrian
2072 (789513)
Old 03-30-2011, 09:06 PM
william1041200's Avatar
That is one big big u-joint !!
Old 03-30-2011, 10:20 PM
westofb's Avatar
Jeff (teet)
Yes that was it thanks!
Old 03-30-2011, 10:21 PM
westofb's Avatar
I am not familar with the 82 series couplers, will look in to it and see what I think.
Old 03-30-2011, 11:32 PM
I have used this style Boston coupling about 2 years, putting on about 250 hours with no wear.
I have used this type of coupling in many things over the last 45 years.
and I like it over the rag joint,as it runs dead true and still has a little flex/cushion.
It also it is a breeze to remove the driveshaft, having only to loosen the set screw and slide the coupling half forward.
My rag joint was still good on the front so I havent replaced that one yet.
Old 03-30-2011, 11:54 PM
Who makes that coupling George? Interesting !
Nice Filter traitor man!!! (Kidding)
