Old 03-29-2011, 04:44 PM
juniors1282's Avatar
Default Parts Donor
Well I found this 1806 yesterday. Went and picked it up today, It's been sitting for several years. The clutch went big time and the guy though the motor went so he parked it. The tins are in good shape just faded from sitting outside in the sun. The tractor has 502 hours on it. I had a little time so I checked compression and it has lots of compression. The clutch is completly distroyed. But I don't care about that. This one is going to be a donor for the 784 the 18 mag is going in it, I'm going to change the harness and everything into 784 so it should be an easy swap. It has a aluminum creeper, that's headed for the 582 . And it has a very well built homemade spring assist on it, which will find it's way onto the 1282 someday. The tins are nice and the seat is in good shape. I should have everything I need to breath life back into the 784. Going to try to get it running later after baseball practice. I'll let you guys know what I make out. Oh yea $300 bucks with a 50" deck
1966 IH cub cadet 102x2
Old 03-29-2011, 05:14 PM
Awesome find, Eric!
Old 03-29-2011, 05:25 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
Nice Tractor, Eric!
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 03-29-2011, 05:39 PM
TEET's Avatar
TEET TEET is offline
Very nice Eric...you and I both love our 82 series I could always use a couple more as well
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 03-29-2011, 06:14 PM
Nice looking 1806 Eric!!!
Old 03-29-2011, 07:47 PM
Thanks guys. Look at those picture's good because that's the last tme that tractor will look like that! It's already torn apart. I'm headed down to see if I can get it fired up.
Old 03-29-2011, 08:30 PM
jbollis's Avatar
jbollis jbollis is offline
Nice find, That is only the 3rd 1806 I have seen. If the dash is nice I would be interested in it, if you don't have plans for it already. The one on mine is pretty bad.
Sold everything but one.
Old 03-29-2011, 09:25 PM
Eric,
You get that M18 into that 784 already?!
Old 03-29-2011, 09:50 PM
Darrell Darrell is offline
Gotta love those twin cylinders !! I would have bought it for the motor also.
BTW , the hood ornament is backards ??!!
Old 03-29-2011, 10:42 PM
ajgross ajgross is offline
Inactive Member
Eric, you're going at it the wrong way! What you NEED to do is put the 1806 driveline in the 582 with a stiffer clutch spring and then you'll really have something. just keep the cast rearend in it.
AJ
