Old 03-21-2011, 08:37 AM
Bernmeister Bernmeister is offline
Default shop lighting
Would you guys have any suggestions for a light fixture for my garage? Right now my main problem is there's no door on it & a previous owner installed a junction box with a ceramic fixture, but birds keep making nests on it!
I'm thinking on a florescent type light & building something around it to keep the critters at bay & maybe even a wind chime to help scare them away lol.
any suggestions?
BTW I will post some pics of the wiring job out there now before I rip it out. It scared me enough that I killed the power the day I bought the place!
Old 03-22-2011, 12:04 AM
Thanks for the info Bill.
I grabbed one of these today, just to see how it will work.
http://www.lowes.com/pd_184349-13537...uantity_sold|1
since it mounts "flush" i think i can set it up so nothing can get in/around it. this is just a temporary setup. to get me through some of the warm nights that are on there way.
the wiring will not be out in the weather, but since theres no door, i guess you could call it "exposed" I was checking out wiring that comes in a flexible metal tubing. (i cant remember the name of it) would that be ok for this application?
Old 03-22-2011, 12:49 AM
dieseldan123's Avatar
Flex metal conduit may be ok. But since i work at lowe's i highly recogmend the use of solid conduit. I just think it lasts longer and if you need to replace wire(s) it should be easier to reroute through it than the flex. Just my worth
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 03-22-2011, 09:44 PM
Bill, as soon as my wife wakes up i will have some pics for you as i dont know how to load them on the computer.
I went this morning and bought the MC cable. (14-2 with green ground) I mounted the light and ran the wiring to a new switch with a metal box. I pigtailed the ground wire to the switch & box, but i was not aware that i needed different connectors so they will be changed before any juice goes to the circut.
& i'm guessing the "anti short bushing" would slide into the end where the wires come out?
thanks a million for this info Bill!
Old 03-25-2011, 08:33 AM
Default pics
here are a few pics of the original wiring.
sorry, the "birdnest pic" didnt come out but i'm sure that anyone would agree that the wiring was unsafe!
the 2nd pic shows a splice in the wiring where it goes through a metal wall, they didnt even use tape on the wire nuts!
Old 03-25-2011, 08:54 AM
Default new wiring.
PLEASE NOTE: even though these are the "after" pics it wasnt fully complete at the time. the wiring is now supported by steel clamps & the proper MC connectors & redheads are now installed.
heres the bracket i made to hang the light from.
heres a shot of the wiring across the stud.
heres the switch. i bought a sealed cover since its outdoors.
Old 03-25-2011, 09:04 AM
I have to put some plywood over the light bracket to ensure no birds will be making a nest on it, but other than that what do you guys think?
Old 03-26-2011, 12:16 AM
Bill, the switch nor any of the wiring is in any contact with rain, i just figured since i was doing the job i would go the "extra mile"
one thing i'm concerned with though. where the cable goes into the MC there is a bit of a gap. the redhead is up against the end but could i put a dab of silicone on the ends to help prevent moisture from getting in?
Old 03-26-2011, 09:18 AM
with any luck it will warm up later in the week. the day i ran the wiring it was 71 & its now in the low 30s!
I have to crawl under the house and run the wiring up to the breaker box & also i bought a GFI outlet for the one outlet showed in the pic. (its the only one out there)
then maybe i can get back to the important stuff like fixing tractors and drinking beer lol.
Old 03-26-2011, 11:57 AM
108cubber 108cubber is offline
I know what you mean about the weather. Be glad when it stabilizes. We all need to get to the important stuff.
KennyP
