Old 06-18-2009, 04:38 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Default Why you should decarbonize
Carbon in the combustion chamber is not like charcoal. It is not flaky. It's more like slag from a coal furnace. It's hard and can almost look like bronze. Here is a piston that for all intense and purpose's would be just fine if carbon had not gotten it. The cylinder wall is as clean as a baby's bottom. The exhaust valve could probably still be used. But it too had carbon build up keeping it from seating.
Old 06-18-2009, 10:56 PM
67hydro's Avatar
67hydro 67hydro is offline
Hey RPalmer, how often do you think we should check on that???
On the 70 the carbon was nasty,and took a good long time to get off/clean and was a pain!! On the 123 the head was prety clean,havent checked on the O yet!!
Thanks for the help
Jason
Jason Davis
Old 06-19-2009, 06:16 AM
RPalmer's Avatar
The service manual says every 500 hours with unleaded fuel. For me that would work out to be something like 1 hr/wk x 52 wks/yr =52 hours a year or about every 10 years. But I think I'm going to start popping heads on every tractor I get.
Old 06-19-2009, 06:36 AM
garrettsdad garrettsdad is offline
Default how?
What's the best way to clean the head? Good ol American elbow grease?
Chris
Old 06-19-2009, 07:56 AM
weaverama weaverama is offline
Chris
I have always found oven cleaner with some fine steel wool to work the best. Elbow grease helps too
Old 06-19-2009, 08:47 AM
RPalmer's Avatar
I did not take any pictures.. hands full of crud and cough up in the moment, but there was a wall of build up that went from the bock to almost the top of the inside of the head that was keeping the exhaust from flowing out. So it was a nice surprise to find that that was basically the smoking problem.
I had a couple of other nice surprises also. This tractor looks ruff. (album #2 100). I got out the garden hose to try and blast off some of the dirt, grease and grass before working on it. I found brand new clutch parts, and a new steering column. This might work out better than I planned.
