Old 03-14-2011, 05:24 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Question Engine Degreasing/Painting
What is the best way to degrease and paint an engine? My K301 is torn down. All that remains is the governer and the front (pto side) crankshaft bearing. Neither of these items I want to remove. Should I wait until the engine is reassembled to degrease/paint? Any tips, tricks, and info would help.
Nemesis
Old 03-14-2011, 05:43 PM
Merk Merk is offline
I will clean block in parts washer and them it goes in a sink that in my garage. I will soap and hot water to do final clean up. I will compress air to help dry the block. My blocks usually just came back from automotive machine shop before I do the last 2 washes. I like to make sure I get all metal shavings out of the block before assembly.
I would replace the governor if it is a plastic gear. It's cheap insurance.
Old 03-14-2011, 06:03 PM
steve59's Avatar
steve59 steve59 is offline
John, I have all my machine work at my local NAPA and they "Hot Dip" the block for me also so they come back looking like this. Then I use self etching primer before final paint.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 03-18-2011, 12:08 AM
Sminkey
Guest
Posts: n/a
Napa? Really? WOW, didn't know they could do that!! What kind of machine work? I like how the block looks after the hot dip
Old 03-18-2011, 02:19 PM
steve59's Avatar
Not all NAPA's have a machine shop but my local one does and they can bore blocks, grind valves and seats and turn cranks.
Old 03-18-2011, 03:08 PM
jkier's Avatar
jkier jkier is offline
That looks great.
Mind if I ask what they charge for the work?
Old 03-18-2011, 03:33 PM
gcbailey's Avatar
gcbailey gcbailey is offline
ya, our Napa is by far not that cool.... Do they do the stuff in house or send it out?
Gary
Old 03-18-2011, 06:14 PM
My local NAPA only does Hydraulics, no machine work .
Old 03-18-2011, 07:58 PM
steve59's Avatar
When I had this block done last year, they bored it, ground the valves and seats, checked the guide clearance and hot dipped it for 100 bucks. Hot dipping is also the way they found a cracked block I had done on a customers rebuild I did also. I have a great way of fixing cracked blocks also.
Old 03-20-2011, 02:43 PM
GoatDriver's Avatar
GoatDriver GoatDriver is offline
Do you care to share your technique?
...or is it "Top Secret"?
Cub Cadet 126 - Cub Cadet 86 - Cub Cadet 108
The majority as to numbers, wealth,and political influence are often wrong. If in such cases a person would do right, he must not be governed by public opinion, however it may be expressed, but by the law of God. {see Proverbs 4:14}
