Old 06-17-2009, 09:33 PM
bombur bombur is offline
Default 129 drive shaft wobble
I bought a 129 recently and took the transmission cover off tonight. I noticed the drive shaft is off center about 1/4 inch about 5" out from the flexible coupling. Does the shaft need to be straightened or is this wobble due to the flexing of the coupling? How would I straighten the shaft? Thanks in advance
Old 06-17-2009, 09:51 PM
young enthusiest's Avatar
I don't know if it even vibrates, so I can't really give you advice. it is possible that is it the coupling, but my driveshaft on my 1200 was bent. I put it in a vice and eyeballed it
Old 06-17-2009, 10:01 PM
Is it just a spot that's off center, or is it the whole back end of the shaft? Either way, I'd take it out and set a straightedge along the driveshaft to see if it's bent. If not, the coupler could be worn and pivoting on the driveshaft. The pre-quietline rear coupling was crude in my opinion. It could be worn out.
Old 06-18-2009, 07:27 PM
To go along with what Matt said, if you find the drive shaft bent, then replacement is the most practical move. Either locate a good used one or fabricate a new one from 5/8" rod.
Old 06-20-2009, 10:42 PM
AHA! The flexible coupling disc is torn on one side! Thanks Matt
