Old 03-06-2011, 10:25 PM
sonnyk sonnyk is offline
Default Hydro Question 149
I have read a lot of excellent information on this site on how it check for slack on the linkages and etc. My question is the damper plate on my tractor has a lot of slack looks like it is on a splined shaft and attaches with a snap ring. i have removed the tunnel cover and it doesn"t look easy to remove it. I am sure it is a lot of wealth of information on what procedure I need to do to remove these parts to replace them or shim them. Do I need to remove the fenders to gain access?
Old 03-07-2011, 05:48 AM
No you don't have to but it would be MUCH easier if you did.
Old 03-07-2011, 09:42 AM
Do I need to remove all the linkages where two slotted bolts are first?
Old 03-07-2011, 06:11 PM
They are way easier to work on if you pull the rear end and hydro out of the frame.
