My 126 has 3-pole lights in it .When I got it the wiring harness was missing .All the wiring diagrams show only 2 post on the back of the bulb. How do I wire one with 3 post on them up to see if they even work ?:bigthink
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
on the bulb you would have a common terminal, and a terminal going to the lo beam filament, one going to hi beam filament. you could check for continuity with a meter first, or put 12 volts across any 2 terminals. It wont short- worst case is both elements lighting dimly.
forget the meter . duh. it should show continuity any way you connect it. unless bulb is bad ...
Three terminal head lamps were never offered by IH. This would be an aftermarket modification made by someone.
Thank You both very much this is good info. I didn't think I ever saw a bulb like this on a cub before. High n Low beams on a cub thats funny.
If you add another switch, like in the footrest, that would kick butt! it would be like a classic car.
How about a SPDT switch? One side Low, other Hi. Just have to run an extra wire for the Hi side.
KennyP |
worked on the lights today. Believe it or not they work high n low. I wired them up using a stock switch. To play with the high n low I just switch the wires around. The first pic is high ,second is dim . Hard to tell the diff in the pics.
What wattage are those lights? The high-beam setting may be more than what the S/G can keep up with.
I'm not sure I'll look later. I'm not to worried though they are mostly for show . I don't do much at night. So they prob won't see much use.
