Old 03-04-2011, 11:08 AM
Luke Shook Luke Shook is offline
Default cub 127 options
I am rebuilding a Cub Cadet 127. I have wheel weights, plow, deck, and trailer. I am researching to see what things I can add durring the rebuild. I've seen a loader on eBay, but that would be too expensive. Where rear PTO's and three point hitches available on this model? What other things should I consider and look for? I plan to sell my 1720 for cash to buy parts and accessories for my 127. I found someone who has a larger deck, three point hitch and snowblower that he'll sell as a lot.
I want to build the 127 with a lot of neat options. I don't plan to sell it.
Old 03-04-2011, 11:16 AM
Start looking for a cigarette lighter and a hydro lift. Do you have headlights for it yet?
Look here for more idea's
http://www.onlycubcadets.net/forum/f...splay.php?f=14
Old 03-04-2011, 12:22 PM
red56turbo's Avatar
Luke,
You could look for a rear tiller and rear lift. The lift is really a one point, not a three point. Can't put a rear PTO on a hydro. There is also a front blade that's IH made and tons of brinly rear attachments, planter, cultivators, etc. IH did make a backblade also. Got any pics of your 127??
Josh
Diesel Cub Cadets...........
Old 03-04-2011, 12:59 PM
Thanks for the suggestions. My 127 has headlights and taillights already. I don't have a cigaret lighter yet. What is a hydro lift? A rear tiller sounds cool. Can someone post a picture of a rear lift and the hydro lift on a 127? I knew about IH making accesories. Thanks for the tip on Brinly. I know that my tractor was one of the last narrow frame Cubs. Are there any interchangeable parts I should look for in other model Cubs? I have a good running 1720 Hydro I plan to sell, and I think my dad has an old 1610 behind his garage he plans to fix and sell.
Old 03-04-2011, 01:28 PM
ihnick's Avatar
ihnick ihnick is offline
Duke. Are the cig lighters rare at all? My 129 and 169 has one
Nick.
Old 03-04-2011, 02:31 PM
red56turbo's Avatar
Luke,
Here's a pic of a narrow frame rear lift on the back of a 72 I used to have. There is a pin that goes in the end of the lift where Brinly attachments or Cub attachments hook. There also is a U-Shaped bracket that bolts behind the triangle tow bracket. On the 1X6/1X7 series, you'll also need the bracket that holds the top cast piece. Used to have a pic of the bracket, but can't find it . Someone else probably has a pic on the back of their 127 and will show ya one on the tractor.
File Type: jpg Cub Cadet 72, decks, sound system 003 (Small).jpg (34.5 KB, 196 views)
Josh
Old 03-04-2011, 03:22 PM
From what I've seen yes they are. I have the part that does the heating part and just have to order a element that gets heated. My current one is from a wheel horse and they are diffrent then the cub version. I'll do some checking to find a older posting that talks about them in a little bit. Great score that you have two of them! I don't even smoke and want one.
Old 03-04-2011, 04:11 PM
westofb's Avatar
westofb westofb is offline
Default I have one!
I have one on my 149, gladly trade it for a rear tiller!
Old 03-04-2011, 04:13 PM
Default pics
cub 127
chains, trailer, weights, plow
File Type: jpg cub 127 plow, trailer, wheel weights, chain.jpg (25.1 KB, 183 views)
Old 03-04-2011, 04:22 PM
Default a rear tiller
Will a rear tiller work on a 127? Does it require a PTO?
