Old 02-28-2011, 09:42 PM
ihnick's Avatar
ihnick ihnick is offline
Default another rear end question.
so instead of finding another rearend for my 100 i'm thinking about pulling the 2 injured ones i have apart. the first one- when you spin the imput shaft there is a rough spot like every other revolution. thinking maybe a bad bearing? the other ive never ran because i parted the tractor. but when i popped the rear cover off there was a little metal ball laying in the bottom which i think is the "shift detent ball". so the questions. which do you think would be a easier fix? and how much of a pain is it to tear apart a rear end? thanks
Nick.
Old 02-28-2011, 11:24 PM
ihnick's Avatar
as of now i just have the wideframe service manual and the wide frame parts brake down book.
Nick.
Old 03-01-2011, 12:15 AM
ihnick's Avatar
So by the sounds of it. Replacing the detent balls will be easiest? I'll maybe look into it tomorrow
Nick.
Old 03-02-2011, 06:21 PM
ihnick's Avatar
whats the torque spec for the big reduction gear? cant find it in my manual. thanks
Nick.
Old 03-02-2011, 06:32 PM
Consult the chart at the front of the manual that has torque specs for different size fasteners.
Old 03-02-2011, 06:58 PM
ihnick's Avatar
Thanks matt. Wasn't sure if there was a certain spec or not
Nick.
