Old 02-27-2011, 07:57 AM
trilakes mower trilakes mower is offline
Default 1200 cub cadet
International Cub Cadet 1200 with 44" mower deck (good shape) and 42" blade.
Also has weight and chain set
What would be the value of this tractor and can I put a tiller on it?
Thanks
Old 02-27-2011, 09:01 AM
Thanks
Nice looking 1200! You can put a tiller on it but will need a creeper gear on it if you don't already have one. A spring assist would be helpful as well. I'll let some of the guys give you a price check on it.
Old 02-27-2011, 10:05 AM
Default mower
Well I haven't bought it yet. the guy is asking 750 for it and its a 2 hour drive away. so in my truck that adds another 100 to it.
Old 02-27-2011, 10:10 AM
jeff k.'s Avatar
jeff k. jeff k. is offline
That price is not bad. Keep in mind if you want a creeper drive for it thats another $200-$300 and a tiller $100-$400 pending on shape.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 02-27-2011, 10:17 AM
In my area that is very high unless the clutch and engine mounts are new. If they haven't been replaced, they will probably need to be replaced, to the tune of about $300+, depending on the condition of the parts.
Old 02-27-2011, 10:21 AM
Default price
I was thinking of offering him $400 for the tractor. but it sounds like I should keep looking and find a tractor that is already set up for everything i want to do.
Old 02-27-2011, 10:28 AM
johncub7172's Avatar
Thumbs up
Hey, That is a nice tractor! Sounds like a good deal, a good package. I wouls ask about the motor ,..how it runs and if there are any major problems. There are alot of IH Cubs here in Ohio, but I sure dont see many for sale. A wide frame tractor is bigger for bigger motors/ power than the narrow frame tractors. Hope you end up with it ! Good luck!
Old 02-27-2011, 10:29 AM
jeff k.'s Avatar
It just depends on how fast you want something. There is probably a better deal to be had some where.
Old 02-27-2011, 07:07 PM
Default other options
after scouring the net all day I found a few other options: the first mower is a 127 and had no price listed what you see is what you get.
the second (2nd & 3rd pics)has liquid filled new rear tires its a 1650 power 3 point hitch, pto, 44 inch deck with mule drive (not sure what a mule drive is) 42 inch snow blade and mount with hydraulic lift lots of new parts. asking 1200
the last mower comes with a tiller, grader, mower deck, 3 point with spring assist. asking 1500. and of course there is the one that I started this thread with for 750. what do you guys think.
Old 02-27-2011, 07:14 PM
Out of the 3 I like the 1650 best. It looks to be in great condition, has a Cat 0 lift on the back, it will also have Hydraulic lift since it is a 1650, lifting by arm with a lift rod anymore. A mule drive is the part of the mower deck frame that the PTO belt runs down and thru to power the mower deck. It has the two pulleys in the front. 1200 may not be too high for that one if it has a lot of new stuff on it as you mention. This is just my 2 cents. Also the 1650's are a hoss of a tractor. Lots of torque with that 16hp motor.
