Old 02-22-2011, 05:44 PM
jholl jholl is offline
Default Add on hydro unit
Hi, everyone. I was given an add on hydro unit. It came off an old ford lawn tractor. It looks just like the add on for a narrow frame cub cadet. I rigged it up on my 86, But I can't get it to pump. Does anyone know anything about these pumps. It was working on the ford tractor. do you have to bleed these things and if so how do you do that. Any info would be appreciatted. Thanks, Jeff Holland.
Old 02-22-2011, 05:49 PM
I'd be willing to bet it turns the opposite direction in the Ford GT, so putting it on a CC makes it turn the wrong direction, which is probably why it doesn't work.
Old 02-22-2011, 07:40 PM
Default wrong direction
Thanks Matt, I had'nt thought about that. I'll check into it. If thats the case, i would have to turn the pump abckwards to make it pump. Thanks again.
Old 02-23-2011, 08:10 AM
nickvanorman
Guest
Posts: n/a
got any pictures?
Old 02-27-2011, 09:42 AM
Default pictures
Sorry Nick, no pictures yet. Once I get this thing rigged up right I'll post some. Might take a while, don't always have a lot of time to work on it.
Old 02-27-2011, 10:26 PM
nickvanorman
Guest
Posts: n/a
every ford tractor ive seen....that runs the Kohler K301 and K321 12 and 14hp motors are set up just the same as the cubs...the driveshaft mounts on the flywheel side of the motor....so unless the pump was mounted on the left side of the tractor...itd be the same as the cub style pump....pics would help. haha. let us know how you make out.
