Old 06-10-2009, 09:57 PM
clint clint is offline
Default Wiring harness connectors Cub 1450
I purchased a new wiring harness for my 1450, I will be needing the connectors on the engine/tractor side. Can anyone point me in a direction to get the connectors, I don't have any pictures or anything to go by, so if someone could snap some pictures of a 1450 wiring harness I have found the wiring diagram, however I think I need a connector/pigtail from the voltage regulator to the wiring harness, or something. I'm going to post a pictures of the wiring harness I purchased, along side the one I took off below. I have a 3 pin connector one the old one, and do not have a 3 pin on the new one, however it may have an extra connector. Just wondering if anyone has a source for the connectors.
Old 06-11-2009, 09:46 AM
jcrews's Avatar
jcrews jcrews is offline
Hi Clint
I hope I have this right but if not maybe Roland will point out my mistakes.
Quietline Wiring Harness
Red - Ignition wire (Green wire –Amp Gauge Negative post)
Upper Black - PTO switch
Lower Black 2 Hour Meter (White Wire - Starter Solenoid)
Green – Stator & Positive Terminal of Coil
Orange – Safety switch
Blue - Fuse
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 06-11-2009, 09:59 AM
jcrews's Avatar
Sorry for the last post here is the picture that didn't post Red - Ignition wire (Green wire –Amp Gauge Negative post)
Blue - Fuse
