Thread Tools
Display Modes
I have a 1650 cub with the 16hp Kohler. It will hit WOT and low idle without any problems but it won't handle a load on it. Example, if I have it at wide open throttle and I press the hydro lever all the way forward, it bogs the engine down. That is the only way I can think to put a load on the engine. The carb is clean and its fresh gas. I know it takes some horses to turn your hydro and the hydro fluid has new Hytran and filter. I didn't no if this is a governor problem or a carb problem or if I am imagining things. Any advice will be appreciated.
75 Cub Cadet 1650 64 Cub 100 not cub but its yellow 62 allis chalmers b-10 |
How old is your spark plug?
What brand is it? Had that problem before. I had a spark arcing through the porcelain part of the plug. Only way I found this is running at night. |
so would that cause it to run poorly all the time or just under a load
Not sure if this will help but mine did the same thing to me would idle at low idle or wot all day long but a load would cause it to shake eraticaly and bog down. I replaced the points and set the timing and it solved the issue.
![]() Quote:
If it is faltering and stumbling and not coming up to rpm, try opening the main jet screw a 1/2 turn (CCW viewing the head) and see what it does noteing the position so you can return to that setting in the event that isn't a problem. |
A bad head gasket or carb gasket could be causing a lean condition but it would run hot also a sticky valve could cause this too.
