Old 01-31-2011, 08:06 PM
D_Ordway D_Ordway is offline
Default 1650 with bad motor mounts
I have discovered my bottom motor mounts have fallen apart leaving me with no cub to plow snow with i guess it will have to sit until spring
Old 01-31-2011, 08:56 PM
Bring it in the garage to repair? The guy I got my 1200 from kept using the 1200 and had to replace the drive line as well.
Old 02-01-2011, 01:24 AM
d_day2613's Avatar
d_day2613 d_day2613 is offline
Default ISO mounts
Really not that bad of a fix. I recently put the solid mounts (saw them on EvilPay, billet aluminum) in my 1450, put it all back together------used it for about 10 minutes, fillings came out of my teeth, then tore it back down pulled the engine again and put the ISO's (new ones) back in and still got the yard mowed by dark. Simple fix. Like the last post says, don't keep running it or you'll end up having to replace the rag joints (which should probably be replaced anyway) or run the chance of dicking up the driveline/engine coupling.
Old 02-01-2011, 02:35 AM
Tractor2nv's Avatar
Tractor2nv Tractor2nv is offline
Default QL ISO Mounts
I have seen them so bad in the past that the stem on the breather wore a hole in the side panel! Fix it,work it and blow some Kohler smoke!
Fool me once shame on you,fool me twice...shame on me!
Old 02-01-2011, 07:27 AM
And the ISO-mount rails, oil pan, etc, too.
Old 02-01-2011, 10:22 AM
I'd also get the Cub Cadet ISO motor mounts from your dealer.
Old 02-01-2011, 10:58 AM
nashcub's Avatar
nashcub nashcub is offline
Just had the cradle mod done for my 1200 and a 1450. Great instructions are provided right here on OCC!
Old 02-02-2011, 01:12 PM
thenrie's Avatar
thenrie thenrie is offline
Those welds sure look a lot better than mine did. My welds probably won't hold water, as they say, but then...
Had a picture around here somewhere. Can't find it.
Tony
Stafford, VA
1650, 682...
Old 02-02-2011, 04:02 PM
i had the engine out in early spring last year and put a set of non cub cadet mounts in it along with the cradle mod when i put it back toghter i used the old rag joints and i knew that i should have gotten the new ones but didnt have the money. The bad thing is now i have to do it all over again but this time im going to change the frame and all since i have a good frame.
Old 02-03-2011, 10:49 AM
RChristensen RChristensen is offline
Inactive Member
D Day2613
I'm glad someone finally tried the solid mounts and admitted that they made the Cub basically unusable. Thanks for the input.
