What is the best way to polish the combustion chamber of a cast aluminum K301 cylinder head? Is it worth the effort? Is there any HP increases?
Nemesis |
It can't hurt!! You can try using oven cleaner to loosen the deposits -- if that doesn't get all of it, then I have used some automotive 1000+ grit sandpaper to lightly sand them away and then use lacquer thinner to thoroughly clean it before re-assembly.
Cub Cadet 123 |
Well, things have been slow lately on this project due to cold weather and the fact my painter has been draging his feet on shooting the red paint. I knew better than to do it, but I "pre-paid" for the work
Nemesis |
![]() Quote:
Nemesis |
Thanks Wild Bill for the information
Nemesis |
Thanks again Wild Bill! Would a 18hp cam(longer duration, stock lift) work fine in a 12hp k301 governed at 4,000 rpm for yard work
Nemesis |
Kirk's cheater cam is a better choice than the 18 horse power cam. I've ran both....Kirk's cheater cam makes better power and is cheaper too.
I did the Killer Kohler mods to my K241 in my 100. Tractor doesn't run out of power. I didn't respond to your orginal question in this topic: What is the best way to polish the combustion chamber of a cast aluminum K301 cylinder head?. There isn't much you can do except try another head. The best head I found is the one that has the spark plug over the exhaust valve. Running a good grade of fresh fuel will make your Kohler run good. |
