Old 01-15-2011, 07:11 PM
Default Safe Air Hammer steering wheel removal
Well it had warmed up today enough that I felt like getting out in the shop and seeing what I could do. I had seen the post in the OCC FAQ about using the air hammer to remove the steering wheel and thought I would give it a shot. I have been preparing the wheel for a few days by spraying it with PB Blaster. I had the 3/8 bolt cut and ready in the hammer and proceeded to pull upwards with one hand and use the air hammer with the other. After 30 seconds I turned the wheel 90 degrees and started again and the wheel popped right off. Was much easier than I thought it would be. I had left the steering wheel nut on the threads but had only put it on 2 or 3 threads to hold it then used a wide washer between the nut and the 3/8 bolt in the air hammer. I disassembled the steering box afterwards and there was no bearing cup damage from the effort. Looks like the only thing I will need to replace in the rebuild is the cam follower stud and seal.
