Old 01-12-2011, 02:13 PM
cdlong's Avatar
cdlong cdlong is offline
Default 6 inches of snow
We got 6 inches last nite. I have the 42" blade, 4 link V bar chains, 70 # weight per wheel and my 214#s. The 1450 did a lot better. Lot less wheel spin, especially in reverse. I like the 54" blade so I'll be getting more weight. Hung the Craftsman rear grader blade off the sleeve hitch. Figured that would be a little extra weight. I'm looking at the hydraulic split kit Extreme
Motor Works has, just got to figure out how to use a hydraulic cylinder with the sleeve hitch. I had to remove the 42" blade to use the rear blade. (Too much trouble).
My 42" blade seems to be higher on the right side. I didn't have this with the 54" blade. I'm using the same blade frame. Blade has a new cutting edge. I removed the lift rod thinking maybe it was the 82 series attaching bracket on the blade, but that didn't make any difference. Could the triangle the blade mounts to be bent/warped? Maybe I did mess something up when I hit the neighbor's truck last snow. How would I check it?
Also, the blade doesn't seem to go down enough, (float?). I have adjusted the knob you set the deck cutting height with. Should I remove this for plowing? The rear bracket the lift rod goes in is not touching the cam.
It was a light, fluffy snow. Wish I had tried the QA36A.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
