Want to thank all of you that helped me out with your tips and advice.I started with what I thought was a good buy back in January. I purchaced a 782 with dual hydros not hearing it run. I paid $400 (maybe to much) but that included a snow blower,rear IH blade,IH box blade and IH Rake.Before even loading it in my truck I sold to a guy from work the snow blower and box blade. I then sold to another guy the rear landscape rake.Leaving me with a rear IH blade and tractor that I did not yet have running for $200 total invested. I first found the key switch was bad. Bought a new one. Then found points were way off. Set them. Then still would not run.Did a compression test and had low compression. (series II motor). Then came the real work. I pulled the motor, pulled the engine covers off. Pulled heads and saw one head needed replaced.Bought two good heads off ebay for $15. Pulled valves out to rule them out as for compression issue. They were good. had starter rerbuilt while out.Put together and in tractor this weekend. Would only run on full choke. Put in new pump. Still needed full choke. Pulled carb off again. Found main needle pluged. Now purrs like a kitten.End or story!!
Now thats a great story!!! and for 200 bucks initial purchase,Wow.
Jason
Jason Davis :biggrin2.gif: Just one more !! ![]() |
wig, Glad to here you are up and running
Good for you man!.
Scott |
You robbed that guy especially with it having dual hyd. Where's the pictures?
will soon post pictures.
That's great wig! Glad everything worked out for you.
