Old 01-08-2011, 05:16 PM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Transmission Problem Cub Cadet "Original"
Hi Guys,
today, i opened the Transmission of my CCO, it's a bad Surprise, in the Housing was a lot of Water, and all Parts are rusty.
Now, i have a big Problem.
What is to do, Repair, or Replace?
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 01-08-2011, 06:28 PM
johncub7172's Avatar
Looks like it will need to be completly taken apart, check eack part and cleaned. You may luck out on this one by the looks of it. Keep us posted.
Old 01-08-2011, 06:42 PM
Sminkey
Guest
Posts: n/a
The teeth look like they're in good shape, I'd take it apart and clean. I think you'll be fine once you get everything cleaned up, good luck.
Old 01-08-2011, 06:58 PM
As long as the gear teeth aren't pitted, they should be ok. I would remove and clean all of the bearings and replace them if they feel rough.
Old 01-09-2011, 08:47 PM
ihc353s's Avatar
today, i removed the Trans, an cleaned the Parts, some Toothweels are rusty, the Bearings are all damaged, and run loudly and rough,
Old 01-09-2011, 08:55 PM
Can you post a close-up of the gear teeth themselves? Pitting on any other part of the gear wouldn't be much of an issue, but if the teeth themselves are pitted...that is bad.
Old 01-09-2011, 09:57 PM
I agree, pitting on the sides of the gears doesn't really mean much. How the mating surfaces look is what's important.
