Old 01-07-2011, 11:17 PM
Sminkey
Guest
Posts: n/a
Default What is this noise?? 147 video
Here's a link to a vid I made of my new 147, got it running tonight finally but she's making a weird noise and was wandering what you guys thought it might be?? http://www.youtube.com/watch?v=AoBrMp4u9Ss
Old 01-07-2011, 11:33 PM
Dave R Dave R is offline
Default Startup noise
I didn't hear anything like you describing. Perhaps its something under the clutch housing shield. It sounded like the engine ran good, other than some carb adjusting, etc. A friend of mine use to say "She was tying every bundle"
Dave
Old 01-08-2011, 12:01 AM
JayBrd's Avatar
JayBrd JayBrd is offline
Pull the cover and see if the rag joints or the couplers are bad....
Jay N.
Eau Claire, WI
RED 82 Series...
Old 01-08-2011, 12:07 AM
TEET's Avatar
TEET TEET is offline
I didn't hear anything out of the ordinary either....sounds like she has great compression. The front pto's can make a little noise as well as the rag joints like Jay mentioned....Ive heard S/G's making some weird noises that lead you to believe its internal to the engine, but really not. She sounds pretty good to me.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 01-08-2011, 12:55 AM
Sminkey
Guest
Posts: n/a
Jeff (teet)
Ok, thanks. I'll pull the guard and see what is going on with the rag joints(whatever they are). I learned so much in the last 6 months about gear drive cubs, not it's a whole new learning curve. I have the manual, will have to do some research
Old 01-08-2011, 12:56 AM
cub123's Avatar
cub123 cub123 is offline
Yeah,the front PTOs and the joints are known to make a clanking noise.The coupler on the engine for the driveshaft always gets a notch worn in it from the roll pin,but other than the noise is no issue.
Old 01-08-2011, 09:59 AM
Sounds like the flywheel screen is loose and rubbing against the shroud,or you have a noisy hydro pump/ problem
Old 01-08-2011, 10:22 AM
Default Flywheel screen
I thought about that flywheel screen too. I've had them come loose and rub with centrifigal force when the engine runs, or get bent and hit the fan shroud when it runs. Just my .02 cents worth.
Dave
