Old 01-03-2011, 12:07 PM
ad356 ad356 is offline
Default 2 dipsticks?
i wonder why my 147 had 2 dipsticks. while putting her back together, im going to just put a cover over the cam and only use the upper dipstick( i have one that is the proper lenght). i was told that the lower dipstick has a tendency to leak so im not going to use it. why did they do this from the factory anyways? does the machine really need 2 dipsticks.
Old 01-03-2011, 12:12 PM
jmroy's Avatar
jmroy jmroy is offline
The upper one is just a fill tube.
Old 01-03-2011, 12:20 PM
gadgetman gadgetman is offline
The 147's didn't have 2 dipsticks, they had a upper fill tube and a lower dipstick due to the addition of the balance gears resulting in interference when using the upper fill tube as a dipstick. This is what I learn off of this wonderful site when I did my research.
Old 01-03-2011, 06:40 PM
MrGitrdone41's Avatar
The upper dipstick is correct. The one is on later engines like in the wide fame series all the narrow frame had the upper one. All of the older IH cubs didn't have a fill tube (82 series did) They use the same tube.
Old 01-03-2011, 07:03 PM
JayBrd's Avatar
JayBrd JayBrd is offline
I think you need to start posting pics of this... I just went to pg 4 here;
http://www.kohlerengines.com/onlinec...1346_c_all.pdf
Or do you have a stick in place of the fill plug like on pg 6 here;
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
Jay N.
Eau Claire, WI
RED 82 Series...
Old 01-04-2011, 12:20 AM
the original engine had a "fill tube" and a dipstick located on the timing gear cover. im installing a standard cover without a dipstick and using a regular full lenght dipstick. im also not using balance gears, they have a tendency to destroy engines, they are going in the garbage.
