Old 01-02-2011, 07:24 PM
Mooner's Avatar
Mooner Mooner is offline
Default Belt removal
OK, so I've decided the S/G belt on my 149 needs to be replaced. What's the best and easiest way to do this? Do I need to remove the front PTO pulley? Cubs are like boats....if you don't like to tinker with them, you shouldn't own one.
Old 01-02-2011, 07:34 PM
steve59's Avatar
steve59 steve59 is offline
Yep.....The PTO belt has to come off first
Old 01-02-2011, 07:45 PM
but not the pulley
Old 01-02-2011, 07:52 PM
Mooner's Avatar
OK, so that sounds fairly easy. Remove the PTO belt and the S/G belt will slip off then too, while the PTO pulley stays put. Yes??
Old 01-02-2011, 07:56 PM
correctomundo.
Old 01-02-2011, 08:05 PM
Yes, pull the pin out of the front pto adjustable rod and take the rod out of the little lever. Push the front engagement lever forward (might need to remove the grill to gain enough room). Take the pto belt off of the pto. Loosen the starter/generator bolts and push it toward the engine to give slack to the belt. take the belt off and replace then put everything else back together.
Don't try to over tighten the S/G belt as it will cause the bearings in the S/G undue wear.
Mooner's Avatar
Thumbs up
Sounds like a piece of cake...
Old 01-09-2011, 12:44 PM
Mooner's Avatar
Well, I finally got a chance to get some time with the Cub today. I loosened the PTO belt and removed it. I took the right-side PTO control lever off and pushed that pulley forward and removed the PTO belt, which was running my snowthrower. Loosened the S/G and removed that old belt too. Went to my friends at the local NAPA and got a replacement belt. Turns out, that old belt was not meant to be on a starter, but rather more like an electric motor. Oh well. The new belt fits down in the pulley much better than the old belt and works great. Thanks Steve, darkminion, and Yosemite Sam. Your help is greatly appreciated!
