Old 12-29-2010, 09:48 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Default Bad day
I was enjoying some cub seat time moving snow around the yard when all of a sudden (look at pics) After closer examination I found that it was cracked perfectly all the way around about 3/4 the way through right by the weld.It fell pretty fast and hard ,there was #400 in the weight box at the time.Had to fire up the 72 to get the 125 back to the shop. Talk about a bad day.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 12-29-2010, 10:05 PM
cub123's Avatar
cub123 cub123 is offline
OUCH!!! That must stink,but thats one more reason to have more than one Cub Cadet!
Old 12-29-2010, 10:11 PM
JayBrd's Avatar
JayBrd JayBrd is offline
wowsa!!! Thank God you're OK.... That sucks bigtime Jeff!
Jay N.
Eau Claire, WI
RED 82 Series...
Old 12-29-2010, 10:18 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
WOW that sucks!!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 12-29-2010, 10:40 PM
I am glad you didn't get hurt. Seems like stuff like that happens when you least expect it. Well, to be honest, I would have never expected that to happen. WOW
Old 12-30-2010, 12:28 AM
Sorry to see that, Jeff. At least, you weren't hurt.
Old 12-30-2010, 06:14 AM
That's why I run loaded tires with wheel weights on my tractors. Take the load off the axle and rear end housing.
Old 12-30-2010, 08:37 AM
ad356 ad356 is offline
how did that happen and what are you going to have to do to repair it? i wouldnt expect that to happen to these tractors, they are overbuilt and have heavy duty rear axles. maybe that 400 lbs was just too much?
Old 12-30-2010, 09:17 AM
Dave R Dave R is offline
Default Broken axle
I would say Sam Mac has the right idea. A little too much weight a little too long and something gave up, in this case it was the axle shaft.
I like the idea of Windshield washer fluid in the tires and wheel weights. I have seen wheels poured full of cement on full size tractors when I was a kid. They devised a way to keep it from sticking to the wheel with maybe canvas and poured it full. They put something in the place of the bolt to keep a hole opening and made their own weights.
Dave in SW Missouri
Old 12-30-2010, 10:31 AM
This is why most of the weight on my loader tractor is on the wheels. I suspect that counterweight contributed to the failure. There is a pretty massive stress concentration where the flange attaches to the axle, and having weight on the frame/rearend increases the stress on the axle flange.
The rear will have to be drained and the axle pulled and replaced. I would replace both axle bearings and seals while you're in there if I were you. You should also get some wheel weights or load the tires, and reduce the side of that counterweight, or you may have this happen again.
