Old 12-21-2010, 06:25 PM
Default Over Bore Question
I finally was able to get out into the shop today with the heater and be comfortable to do some work. I was able to finally check the bore wear on my K301. After looking at the measurements, it looks as if the bore has been wore to a .020 size from standard. It is very consistent top to bottom and yes I did check it at the six locations as per the Kohler manual. 3.3950 was the average measurement. My question is obviously either .030 over is what I will have to have it bored too, or, Seeing how the K301 and K321 are essentially the same except for bore, can I just punch it out and go with a standard K321 piston and rings in it. I was not sure if the blocks of each engine were the same? Does anyone have differing view or suggestion. This is the 128 I got from my grandmother so I don't have an issue such as having a 14hp piston in it as it will never go anywhere but here then to my daughter way way way down the road ...
Thanks for all the input.
Old 12-21-2010, 08:09 PM
Think I found the answer to my question. There seems to be a balancing issue in regards to the larger piston of the 14 and 16hp pistons in. The K301 and K321/341 cranks have the same stroke, but are different due to being balanced for their respective pistons. A 14 or 16hp piston can't be used with a K301 crank. It will vibrate too much and the rod could have a catastrophic failure. OK looks like I'll be boring it .030 over or sleeving it.
Old 12-21-2010, 09:30 PM
Not to mention not all of the K301 blocks can safely be bored to the K321 standard bore size and leave sufficient cylinder wall thickness.
Old 12-21-2010, 10:39 PM
That was my main concern and didn't know how to tell if one was thick enough or not.
