Old 12-21-2010, 08:03 AM
smoker62's Avatar
smoker62 smoker62 is offline
Default 1250 lift height
On my 1250 with hydro lift, the QA42A only comes up about an 1" off the ground. How do I verify that I am getting full lift height with this. If I remember when the plow was on , it would lift it maybe 4" or so.
Old 12-21-2010, 08:37 AM
CubQuest CubQuest is offline
I'd say that the lift rod is probably too long. You can verify this by removing the tunnel cover and looking to see how much the rock shaft moves before the QA42 starts to lift. If you use a length of chain or cable in place of the solid rod you can adjust the length to get the full amount of lift.
Old 12-21-2010, 09:12 AM
smoker62's Avatar
The pivot on the side that the rod mounts to will move all the way back when the rod is disconnected. When I put the rod on , it stops half way back. This is the pivot by the right foot rest , not sure what its called. The pivot is all the way forward when it is down , so in my mind , shortening the rod would not let it go down fully. Maybe I am not thinking correctly . I will have to check it out again, thanks for the idea.
Old 12-21-2010, 11:19 AM
Sounds like you have a sheared spirol pin in the rockshaft.
