Old 12-08-2010, 06:27 PM
cub149's Avatar
cub149 cub149 is offline
Default 149 headlights
I need a new set of headlights and was looking at an old post about a halogen bulb that will fit. It was a GE H7605 50 watt bulb. I called NAPA and they don't have that nor do any other parts stores here. NAPA has a Wagner BP 1255H7 that is 55 watts. Would this work? Also I am concerned if the cub wiring, electrical system, etc.. will handle this. I don't want to burn up any wires.
Chip T.
Drexel NC
Old 12-08-2010, 08:09 PM
Most Cub wiring is rated for 15 Amps (14GA Wire). 55W will draw ~4.6 Amps. You should be good to go.
Old 12-08-2010, 08:18 PM
I'm going to assume he's going to use 2 headlights, so that'd be about 9.2 amps. Still should work, but I'm not sure what size fuse is in there. If it's only 10A you might have issues. I think the starter/generator output is 15A, so you should be fine as far as that's concerned as long as the starter/generator is in good shape.
Old 12-10-2010, 12:12 AM
I've run both 15A and 20A fuses and never had any problem yet. I've found that TSC (Tractor Supply Co.) has very reasonable prices on headlights......about 9 or 10 bucks each and I think that they are Wagner. The GE's at a local JD dealership are $25 each.....but their items are made of gold, right?
Old 12-10-2010, 12:41 AM
johncub7172's Avatar
I'd just like to point out that both front lights on my 71 are halogen motercycle lights. I believe I'am running a 25 amp Buss glass fuse in a marine-type holder. No troubble keeping the batt. charged when running or burned up wire. Using 16 gauge wire.
