The paragraph in quotes below is direct from page 15 of the 800 - 1650 Operator's Manual... what I need to know is where is this Release Lever on a 1650 QL?
"To push or move the tractor for a short distance, the release lever must be held in the (up) position and the speed control lever must be in the "N" position." Thanks! |
it's possible that it doesn't have one. Later QL's used the auto style valves. if it had the release lever it would be located on the side of the tunnel cover.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Thanks AJ !
Before you go pushing it around thinking you have auto valves, you should remove the tunnel cover and verify that the valves are flat on top and do not have a plunger. If you have a plunger on one or both I would not advise pushing it to move it.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
